unvented secondary return
View the thread, titled "unvented secondary return" which is posted in UK Plumbers Forums on UK Plumbers Forums.
M
mike_s
Can the pump be connected to a flow switch? I thought I seen this somewhere, I've got a customer who has one of these systems and finds it annoying how everyone has to synchonrize their showers unless the pump is on all day and evening so I thought a flow switch would be obvious as the pump is only required once the hot taps are turned on preventing the long wait for hot water?
I've just been re-capping about secondary return circulation in 2 unvented text books but no mention of a possibly flow switch. will speak to manufacturers tomorrow about a possible solution.
Thought at first it was a good idea, but I'm not too sure the more I think about it. It will only operate the pump on opening and shut off again when tap closed, could have a pump over run on it, but still means first draw off has to wait. Prefer a timer on the pump to operate at peak times.
Might need some more thought.
What is a PIR? Ecowarm why would the pump stay on once the tap was turned off?
Probably not the best idea after reading your thoughts, just thought there would be a better alternative to it being timed. I know it wouldn't be as quick on a flow switch but may still be an improvement I thought.
The cylinder and secondary circulation pump timeswitch are in the loft, maybe they would find this switch more convenient in the bathroom. I never installed the system.
it need to stay on so it deliver hot water ready to be drawn off from the taps when ever is going to be the next time ,eliminating waiting time and kill the dead leg ,plus if it has temp sensor it will maintain correct temp in the pipe work ,so if it cool down over night you dont have to wait 2min for the worm water to be delivered ,my personal understanding of the hot water pump
It would turn on when tap opened and then stay on! you need a timer
Yeah it does work, we have done it before. Put it near the door to bathroom/kitchen etc, then have it on a 20min/30min run over then it shuts off. It works a treat and only comes on when someone enters the room.
but then will it maintain the correct temp in the pipe work ,so when you get in the morning and open the hot water tap
will it be there any hot water .....or you have to wait in the shower to get the water which to me it will make it less useful in this scenario .pls correct me if i am wrong !
A secondary pump is used to reduce the lag time for receiving hot water to long distance pipe runs.
Why not wire in an old fashioned Immersion heater timer ?, set the pump to run for a short blast of 15 mins and then off.
Set this to happen during the day and off @ night.
If the water is cold when demanded then there is a problem with the insulation of the hot water pipes and the secondary return.
Kev.
you mean put the pump in the bathroom or put sensor there ? as if pump is in bathroom and there is more then one dead leg and the other shower is 10-15m away it will not do much ,will it !
I'm thinking this temperature sensing pump sounds great and if it's quieter then that's better if it is to be timed to be on all day. I may suggest it if the noise is an issue.
I don't get this. What if you walk into the bathroom and go.straight to.hot.tap and.turn it on? The pump won't have had time.to circulate the.water and you'll still have to wait for the water to get hot completely negating the whole point of.having a.hot return. Or am I being thick?!
Put the sensor just inside the doorway off the bathroom, by the time you run the tap you should have hot water. It should only take 10 odd seconds to circulate it around the pipework.
I was replying to the OP's question regarding a flow switch
Just noticed you was the OP, sorry
Sorry bud, that is the whole point of a Secondary return. 10 seconds ? of wasted water in a hotel/ large home is a lot of money.
The secondary pumps are nowhere near as powerful as whole house pumps/ shower pumps. Hence the reason they can be left running 24hrs a day without noise in a well designed system.
Yeah I realise that it wouldn't work on a large home/hotel, the place we used it at was a very long cottage. The kitchen sink was about 5/6m away from the door, so by the time the sensor picked you up and got to the sink to run the hot tap there was hot water there.
I'm not saying it will work in every situation but its certainly something to keep hold of if you ever get into that situation.
Hi, I'm new in this forum, and I have a secondary return problem. When we came to this house, there was a secondary return circuit. The secondary return covered the upstairs taps, and returned to a connection half-way down the cylinder. It was entirely gravity fed, but it worked pretty well.
Then the cylinder burst and the plumber who replaced it in a hurry fitted a cylinder without the half-way-down connection, and just cut off the secondary return circuit. It's been irritating to have cold water in the upstairs taps. I've finished my shave before it gets hot.
I have no intention of doing this myself, but I'd like to make sure the circuit is OK, before I talk to a plumber about it. It seemed to me that something like this would do the job. Any comments?
Thats the standard way to do it when cylinder has no stand alone secondary return connection. Tee'd into cold feed.
Did not mean that what Si said is wrong ! Did mean that it should Have a connection at high level to cylinder where is connecting to cold feed as is the only option
get your plumber to fit an essex flange on your new cylinder, it will save the cost of an expensive bronze pump, nothing wrong with putting the secondary return on the cold supply as you have shown, lots of unvented cylinders show this in the installation instructions.
As this thread relates to 'unvented' secondary returns I wouldn't be fitting an essex flange on an unvented cylinder. I think gil needs to expand on his issue or start a new thread. i.e. is it unvented or vented?
A secondary return on unvented cylinder should be pumped with a bronze/ stainless pump
it will still work as gravity without the pump but best option has all ready been mentioned get an essex flange fittedthis keeps the hot water at the top of the cylinder without it mixing with cold
Umm... I'm not sure whether it's vented or not. How would I find out?
In case it's relevant, we have another problem in that there seem to be air locks in the system since the cylinder was replaced, and if you run a tap at the beginning of the upstairs run, and then open a tap at the other end, there tends to be a lot of coughing, and some of that seems to be bubbling out of the attic tanks.
I seem to be getting into deep water :smug2: here,
Doesn't sound like it's unvented. You wouldn't expect to get air locks and with unvented you wouldn't have 'attic tanks'.
Can you post a picture of the cylinder?
Re: secondary return - vented or unvented?
This is it, essentially the same as my diagram, but much messier.
Oh, yes. It must be vented - I looked up Essex flange and saw a diagram of a venting pipe leading into the attic tank. I have one of these. It's a very old system that's been mucked about with, if that helps.
Praps some kind admin should shift these posts into a separate thread.
Yes it's vented
If you leave the secondary return on a gravity circuit your wasting a lot of hot water as it's cycling all the time the water is heated
Reply to the thread, titled "unvented secondary return" which is posted in UK Plumbers Forums on Plumbers Forums.
mike_s,
fuzzy,
