Nov 30, 2023
london
DIY or Homeowner
Anyone know what might be causing this situation please? We have replaced the EV and non-return valve but still happens.
Normal static pressure on that gauge is 2.5 but it builds up overnight to 3+ and then the problem occurs.
Were a bit lost and had a few engineers look at it.
At this point if someone helps me out and solves this happy to send over some beers (money) your way!
If turning off the heat sources to the cylinder solves the problem (try it a few nights), report back.
If it doesn’t solve the problem, report back.
Hi - ok so did some tests and pressure upstairs as measured on guage goes beyond static 2.5 to 3.5-4 when the hot water tank is being heated by gas.
When I then draw hot water from tap get the horrible noise and it seems to be coming from the EV side.
N
2K
UK Plumbers Forums
Novice needs help
N
