View the thread, titled "Upside down cistern fill valve.." which is posted in UK Plumbers Forums on UK Plumbers Forums.
On a job today and asked to change the WC cistern, supplied by customer from a supposedly 'better' online bathroom supplier.
The instructions looked a bit suspect as if translated direct from Chinese.. Anyone seen one of these before??
The inlet valve(pictured). No it is not upside down.. The shut off valve is actually at the bottom thus totally submerged under the water. Suspecting 😱 this did not comply with the air gap I refused to fit. And changed the fitting for wras approved ones.
How are these big companies allowed to sell these.
So would this get WRAS approval.
Some Wras approved products still need installation requirement notes (IRNs). Eg an inlet valve can be wras approved and yet needs a double check valve as it doesn’t meet the back flow requirements, but it does meet the materials in contact with water requirements and can therefore be wras approved.
could not find any wras approved indication. Just a bit on the bottom ''Producting of china top standard'' ..did not convince me of quality 😵
On the subject of bottom entry inlet valves, I recall someone on the forums fairly recently posting an advisory they had (from where I cannot remember, maybe the water supplier?) been sent in writing that even the "top notch" fluidmaster pro valves now need a double check valve installed on the supply. They were getting reports of blue water in the mains supply caused by blue cistern blocks (blocks of the devil) and water back flowing into the mains and dying the water blue.
Does anyone else remember this?
On good valves there is a line (can't remember its name HELP!) where you must install so this is 25mm (if mem serves) above the fill line. As so few people did it, or even knew of its existence, I suspect this is to 'replace' or supplement that.
Yea so it would be approved / comply without extras being installed
Sorry. Confused. WRAS approval may be granted even though it requires additional/supplementary work in order to comply such as double check valves (R160).
Take the B24011 NABIS & B24007 NABIS. Each of these require a double check valve to comply with their WRAS approval (#1407087), YET neither is supplied with one.
Yes so install one without it it doesn’t comply / have wraps approval as the bits required for wras approval arnt fitted
Mr Ray, why you no fit our walve? Very good walve Mr Ray!
I love Chinglish, it’s an amazing place to work if you ever get the chance. They’d much rather you bribed them to say whatever you’re there to fix is fixed than actually fix the thing in my experience.
Reply to the thread, titled "Upside down cistern fill valve.." which is posted in UK Plumbers Forums on Plumbers Forums.
Thread starter
Joined
Location
Cambridgeshire
General Plumber
Thread Information
Title
Prefix
N/A
Forum
UK Plumbers Forums
Start date
Last reply date
Thread Tags
RayPlumb,
OffshoreGas,
