U
unfinishedsweet
Downstairs hot water in taps is very hot, upstairs is warm and the flame in combi boiler doesn't burn on full as it does while downstairs tamp open. That are the possible reasons?
not enough flow rate thru taps up stairs? diaphram getting old ?Downstairs hot water in taps is very hot, upstairs is warm and the flame in combi boiler doesn't burn on full as it does while downstairs tamp open. That are the possible reasons?
......Do you have a shower upstairs with a mixer valve? could be passing cold thru. Isolate cold water to boiler and run hot tap. If there is flow then that may be the prob
Reply to the thread, titled "upstairs hot water warm" which is posted in Air Sourced Heat Pumps Advice Forum on Electricians Forums.
