Guest viewing is limited
Using basin taps for a bath
View the thread, titled "Using basin taps for a bath" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hi, I'm building a new bathroom and wondered if it is necessary to fit bath taps for the bath.
My Duotec combi boiler has a hot water flow rate of 16 l/min and a lot of basin taps are rated more than that.
Using basin taps would make the pipe fitting easier ( taps will be wall mounted with supply and waste pipes hidden in partition wall )
My logic makes me think that as my hot water coming from the boiler is in 15mm pipe then there is nothing to be gained by using 22mm fittings taps.
Any advice would be appreciated.
You'll fill the bath quicker with bath taps, even though they will share the 15mm feeds, the tap connectors for bath taps have a larger internal bore and the valve in the taps and all other parts where water would pass inside them are generally bigger bore too, not sure how noticable it would be to be honest though.
Thing is though if you exceed the flow rate of your boiler the water you get from the taps won't be as hot so regardless of the taps you use you probably won't open them fully anyway.
So to summarise:
Probably fine although they may look a bit small.
It's your house! If your thinking of selling at any point. Stick to the norm, or you may lose money.
Thank's for the replies JCplumb and Steven.
That confirms what I thought, that using larger bore bath taps would allow an increased flow rate but the water wouldn't be hot enough for a bath so the bigger bore taps would be pointless with a combi boiler.
Is it against regulations? I wouldn't have thought they'd notice different taps in a Home Report.
You could always use bath taps and put service valves behind bath panel to throttle back flow if ye wanted to use combi.
Might not b ideal but if ye have yer heart set on combi ye could go that way
A lot of standard type bath taps use 1/2" works identical to the same basin taps.
But the rest of tap body, as has been already mentioned, tends to be bigger, so better flow.
I would go with the bigger bath taps, as often you need to fill the bath fast and not all with hot water
Thanks Best. I didn't realise that there are bath taps that use 1/2" connections. I'd be happy using them as it's the easier plumbing, using 15mm pipe and connections, that I'm after as the supply will be inside a 4" partition wall.
I wish the tap advertisements would give the connector size in their description.
Reply to the thread, titled "Using basin taps for a bath" which is posted in UK Plumbers Forums on Plumbers Forums.
kennyd,
kennyd,
