Guest viewing limit reached
using hep in upstairs 1st fix
View the thread, titled "using hep in upstairs 1st fix" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
M
mark_mc
what is everyone think of using hep in a understairs 1st fix in a house.
thinking of using hep in a house but only in understairs and drilling thru joist.
what are your experience etc.
thanks
that is what i was thinking thats mad pressure. we do sprinkers and we never test to that pressure and its screwed iron, if i had to test at that pressure i will run the hose out to the van and take cover just incase.
wouldnt want to wreck my pretty fa
I see. That's the way I work, I use what works best for me. Not had any experience of Hep, but used Speedfit many times and not once had any problems with anything I've installed. Only probs I've seen are where diy'ers, joiners and other trades fit it incorrectly and then through time it blows off!
My all time preference is yorkies and copper, but copper is too bloody expensive and using a gas torch gives my insurance company the heebie geebies!
Would definitely test more than 4 as I have had fittings with the teeth not properly engaged cling on until 10 bar then pop off!
very good point and its true.
when i tested a 1st fix with hep got to 10bar and everything started to click it must take that pressure to engage the teeth
and as he said they reccomend 16 bar demountable fittings and 18bar for the slimline
Plus you should bear in mind that this is all cold testing. Once you put heat into pipes leaks can appear where there weren't before when cold tested.
I have used some of the new hep white fittings on grey pipe but not used the white pipe, my only concern is that if you mix hep fittings or speedfit fittings on either of there pipes your supposed to use the correct insert for the pipe so if in the future you see white pipe on a job you may automatically assume that it is speed fit and install the wrong inserts
Reply to the thread, titled "using hep in upstairs 1st fix" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
mark_mc,
unguided1,
