Wouldn't put denso tape round plastic pipe - don't know how the plastic will react to the grease.
as stated to the rocket scientist in the house if you are going to put insulation around the pipe which is obvious if your putting in concrete as the pipes will just burst with the concrete when the pipes expanding etc then wrap in densil tape so no concrete gets through to the pipe at all
Concrete won't damage plastic pipe and for the comment plumbster
Would you lag and wrap in denso underfloor heating pipe as it's plastic
Acording to your comment it will burst lol catch yourself on
THE PLASTIC IS IN INSULATION THE DENSIL IS AROUND IT WHY WILL IT REACT? i THINK DENSIL IS BETTER FOR PLASTIC THAN CONCRETE DONT YOU? COME ON THINK ABOUT IT
ok proffeser gray you can put plastic in concrete all day long if you like but you trying to tell me that if say it is heating pipes with push fit fittings that way expansion and contraction those pipes wont burst? ok rocket scientist you do that if you want i wont.
and as for under floor heating I am not going to pretend to know lots about as i dont but if this is allowed to go under screed or what ever i can gaurantee you it will be a different grade of plastic with the push fit fittings placed in allowable areas.
didnt you learn at college or did your 6 week course teach you nothing co efficient linea expansion I thought a rocket like you would no this
I've seen it done before but I just don't like the idea of it. I use Uponor MLCP pipe with crimped fittings,more expensive but fit and forget.
Hep doesn't use the green grab rings anymore though,it's white now too.
