Hello everybody! I need your advice regarding that solution: Distance between two radiator pipes(valves not included) 1000mm,standart sizes of radiators are 1000mm and 900mm.If i put TRV and lockshield valve, i would need smaller radiator than 1000mm(I believe old radiator was around 950-960mm wide).My question is: Would it be a problem to get 2 extension tails(50mm) each and install them on both sides of radiator valves(TRV and Lockshield)? In that case i would need to get 900mm wide radiator.Or there is some another solution i can do?
P.s I have looked for 950mm wide radiator and i cant find them anywhere. I believe my radiator was that old 🙂
Thank you for your help.
