Vacating flat. What to do with Combi boiler?
View the thread, titled "Vacating flat. What to do with Combi boiler?" which is posted in Boiler Advice Forum on UK Plumbers Forums.
I have an Ideal Logic Combi C30 boiler in my flat.
I am now vacating the flat, and so the boiler will not be used.
How should i switch it off?
Does it have a gas pilot flame in it that i must extinguish? Do you know how to do this?
In the consumer unit, there is a breaker for "Boiler". Presumably i should shut this off?
Also, the main appartment gas valve is under the consumer unit. Presumably i should turn it to "off"?
Turn the water off at the stop tap and leave the boiler on off on the front control panel or turn the room thermostat down to min
Could be vacant for 2 months....is it dangerous to turn anything off?...eg the gas flame might cause probelms if the electric is turned off.....ie nothing to control the gas flame?
Thanks very much indeed, and should i turn the gas off?...and also, turn the breaker off in the consumer unit?(the one with "boiler" written on it).
Is it ok to turn the water off to the whole flat?......wont that kind of mean something going wrong>...like you end up with the toilet water level going down and then get air bubbles in the water system...or something?
I wouldn't normally isolate the gas but it won't do any harm. The breaker can be left on though.
The water being off wouldn't effect the trap levels in the toilet etc. You may want to leave plugs in sinks etc though as the traps can dry out over long periods.
Reply to the thread, titled "Vacating flat. What to do with Combi boiler?" which is posted in Boiler Advice Forum on Plumbers Forums.
boilerboy22,
Scott_D,
