Guest viewing limit reached
Vaillant combi boiler - no wall thermostat or dials
View the thread, titled "Vaillant combi boiler - no wall thermostat or dials" which is posted in Boiler Advice Forum on UK Plumbers Forums.
wheres the white condense pipe go? outside?
the boiler requires a stat for boiler interlock and it will also save you £30-£100 plus a year at a guess.
it should be increased in size internally before it goes outside otherwise its likely to freeze leaving you without your boiler working on a very cold day.
Ok, didn't realise that, I'll use that as more ammo for when the council get back to me! Cheers.
So it's a glowworm not a valliant. The gas pipe is sleeved but not sealed to the building fabric nor is it sealed to the gas pipe.
Reply to the thread, titled "Vaillant combi boiler - no wall thermostat or dials" which is posted in Boiler Advice Forum on Plumbers Forums.
GeorgeOz,
Ermintrude,
