J
julesverne
So i'm looking to expand on the boilers that i install.
not knowing anything about vaillant.
whats the difference between the 2 types of boiler.
Longer warranty, built in filling loop and different DHW outputs, inside I believe they are the same
Plus is full brass inside, pro is plastic. Plus has siphonic trap, pro doesn't. Pro is crap, plus isn't.
Better off offering logic and vogue IMO.
Tbs we should start a campaign for logics and vogues. They are the cheeky girls compares to intergas - jedwood?
Reactions: 2 people
i do like logics but if somebody wants a vaillant and are set on it then i will install it.
Haha.
Can't remember what warranties are at the mo, haven't fitted one for so long. Might be 5 and 7 years for advance installers?
Won't matter though cos if you need a warranty claim they'll not turn up for a week, blame you for the fault and wriggle out of the repair.
Haha.
Yeah Its 5&7 if you sign up to the advance installers. I thought they were the same internally?
Ecotec pro is 2 years without advance or 5 with advance
plus is 5 years as standard or 7 with advance.
having had my head in both the plus is the better one, more brass less plastic.
Plus has another sensor on the DHW as it leaves to boiler. All the ntc sensors are the exact same so if one goes you can rob the DHW pipe NTC leaving the jack disconnected and it wont effect it bar the hot watervarying slightly while in use.
Haha.
Bloody hell, so much for warranties then 🙁
Haha.
I'm not keen on ecotecs I had a fault on one rang tech up the guy was an arrogant **** talked down to me I won't be fitting vaillant.
I ve fitted Vaillant pro s and plus very good boilers IMO had very little problems ,as in previous posts 5 and 7 yr warranties ,if customer has problem usually f75 which is pressure flow switch ,I put the call in and the eng.is out next day .however the rep has informed me today that they a withdrawing support and a 5% price increase in March it has put the price up £100 on a pro which is making it far too pricey ,when you compare it with a baxi duo tec 28 the pro is £200 more !!!
