G
Gasman1987
hi there, today I was called to a house to service a vaillant ecotec. the boiler was first installed in 2008 and has been serviced yearly since. the gas to this property has been off for somewhere between 10-16 weeks so the boiler has been inactive.
anyway, during the routine service, I removed the burner carried out a visual inspection, cleaned and fitted a new vaillant graphite seal (burner looked normal) fired up the boiler put my analyser in the combustion side and it was giving out crazily high readings. ie
PPM: 31000
ratio: something around 0.3555
c02: 8.0
I know the c02 isn't that far off but whats going on with the other readings? Ive had slightly low and high readings before which I have adjusted but these are way out. burner visually is fine, and have also inspected the flue and it appears sealed and normal.
I then put my analyser In the oxygen side and got a reading of 20.9 which Is correct but It gave a reading of over 500 ppm when it should be 0.
can anybody please offer any info as I have never seen such ridiculous readings. analyser is fine as I have used it since.
thanks
Sorry,
please increase your post count to 10+ then send a PM (Private Message) with your gsr details to either Gas man - View Profile: gas man - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK or Redsaw - View Profile: REDSAW - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK who will check you and then give you access to the gsr private forum.
Providing gas-related advice to anybody who should not be touching gas and cannot prove their competence is unacceptable. We will take whatever action we deem appropriate to prevent such advice being given
Thank you.
UKPF TA's, Mods and Admin teams.
http://www.ukplumbersforums.co.uk/central-heating-forum/42241-notice-gas-safety-related-advice.html
