Op posted again today.
May be worth a go at getting Vaillant out on a fixed price repair?
I will be calling someone else, someone who's knows the Vaillant like the back of his greasy hand! 🙂 With a drop that big, are you saying it's more likely to be the boiler at fault? If that's the case then it's a slight relief as I don't fancy having to gut the flooring to redo the pipework!
that is the first step by you to trying your diy skills on your boiler now.But are you also worried I may blow myself up? 🙂
you rang ?Checked the PRV outside and it doesn't look like it's ever discharged. I did however find a leaking conex on the heating flow going into the cylinder and evidence of a recent leak through the ceiling which was just another conex which needed nipping up. All fine now anyway and I told them to hit the Conex Kid with that filling loop if they ever see him again.
Seeing as I only went out to speak to them about a shower it's ended up being a good evening. They want a new kitchen fitting too! *Dances*
Reply to the thread, titled "Vaillant Ecotec Plus 831 losing pressure overnight" which is posted in UK Plumbers Forums on Plumbers Forums.
