SomebodE
Hi all,
I'm new and was hoping for some advice.
We had a Vaillant 637 boiler installed last year with a Aurastor 260L (solar coil connected to boiler loop via a piece of pipe but allows future upgrade, suggested by Vaillant phone support) prior to a loft conversion. Also have a VR65 wiring centre and VRC 470f controller.
I know it's a large boiler and it was a throw up between the 630 and the 637 - we opted for the 637 as the difference was about £80 total.
Everything has been working normally since installation aside from the pump running occasionally - no demand indicators show, burner not firing and it does it every 10-60 mins when there is no demand. Is this normal?
It recently had it's first year's service and there was a "F.78 Fault DHW Sensor disconnected" fault code registered under the installer level. I was asked to register this with Vaillant under the 7 year warranty. Can someone explain what it means? Should I be concerned?
Is this something inside the boiler that Vaillant need to look at or is it outside that a competent person can look at?
Thanks in advance!
Thanks in advance!
