K
kitkat
hi This is long complicated story, please bear with me. I had this boiler fitted 6 months ago. There have been problems with one radiator which needed bleeding almost everyday and made the occasional noise like breaking wind in the bath. Plumber could not fix. then 2 weeks ago the heating and water would not heat properly.. Radiators warm at top, cols at bottom Plumber said it's the heat exchanger. Vaillant engineer came & said there was a lot of iron oxide in the boiler water & the pump was noisy. Also the TF1 magna filter had not been fitted( we have paid for this). He recommended pump is cleaned out. Also said the temperature differential is too high so boiler keeps cutting out. Plumber admits he made a mistake in not fitting the filter. He drains the system says its not so bad but water around the pump was gloopy. Says water is dirtier now than when he fitted the boiler 6 months ago. Replaced pump ( 1 year old) & put in a chemical - Gold 500 I think. Makes no difference- still boiler cuts out, radiators upstairs got luke warm , then cold after 2 hours. Downstairs did not heat up. Plumber now thinks there is air in the system & a leak but can't find it. Now thinks leak is under concrete floor as the outlet pipes where we drain the system from (which are in the wall) are loose. He is coming back to flush out the system and fit the magna filter. He still thinks it could be the heat exchanger. I am at my wits end. I don't know what to believe anymore. Could it be a leak? Could all this have been caused because he did not fit the filter? Is there anything else that could be causing this? Thanks
