Van-Pack Jetter Unit
View the thread, titled "Van-Pack Jetter Unit" which is posted in UK Plumbers Forums on UK Plumbers Forums.
G
Ged Simpson
I have a Jetter unit designed to fit in a midi or transit sized van for domestic and light industrial drain cleaning.
SPECIFICATIONS:
Power Source: 25hp Kholer Industrial V-Twin petrol engine with electric starter
Power Unit: Triplex ceramic positive displacement plunger pump
Pressure Output: 200bar (3000psi) @ 36 l/min (8 gpm)
Transmission: Close coupled gearbox
Pressure Hose: 60 m high pressure rubber hose on reel
Refill Hose: 25 m low pressure 3/4” hose on reel
Water Supply: 250 litre (50 gal) steel water break tank with ball valve inlet
Anti-freeze tank and valving arrangement to protect pump from icing up
Automatic unloading valve to unload back to tank at 3000 psi
20 m trigger operated mini-jet hose adapter
Trigger operated hand lance for power washing
Very good condition (± 10 hours of use)
Price £1800 ONO
Dear Mr. Ged Simpson,
Yes, I am interestead.
I want to start a new bussines in my hometown, Galati, SE of Romania in drainage cleaning.
In our town this kind of services (drain jetting) are not available, so I hope it is going to work. Galati is a town about
250.000 people.
If you have any piece of advice for me as I am a begginer in this area it will be very much apreciated.
So my plan is to come to UK with a van to pick it up, if we agree about the jetter unit.
About the jetter unit, can you give me more details. You said it has about 10 hours of work? That means is almost new?
Can you tell me (aprox) the petrol consumption per hour? Kholer is the same company with Lombardini?
Thank you,
Ben Bulugu,
[email protected]
Hi Ged
Long time no hear from o hope your doing well and still plumbing
I might know someone who will take your jetter is it in a van or on it's own
Alan Paul formerly plumblocal but now plumber24
07903174498
Surprise, surprise, hello Alan, nice to here you're still operating. No I'm now retired from plumbing, just couldn't drum up the work so the van has also gone, but the jetter has been removed, so will be easy to load up or fit as required. The photo was taken immediately prior to removal so they are nor "old" pics. I keep an interest in the forum just to keep an eye on how things are going.
07917048592
It's a shame,there were very few who came out unscathed from what can only be described as a con in the end, originally the idea was sound and good it would even be successful today if it was run by people who not only knew what they were doing but had the drive and passion to see it through
Anyway enough of that it takes me back to the bad old days, I did need a jetter with a van because my son wants to try and start his own drainage company he's got a vw caddy on a p plate that's a great runner do you fancy doing a part exchange, a jetter for a van, the caddy will not take a jetter because it's small,so I'll have to buy a bigger van anyway if I can't find a jetter and van
07903174498
[email protected]
Reply to the thread, titled "Van-Pack Jetter Unit" which is posted in UK Plumbers Forums on Plumbers Forums.
Ged Simpson,
Ged Simpson,
