Van stock how much do you carry?
View the thread, titled "Van stock how much do you carry?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Millsy 82
My van always seems full but you can always guarantee that I dont have the bit that I need so end up driving to the merchants. It is always nice when you go to a job and it's a faulty 3 way valve you walk to the van and come back in with a new one the job is done within an hour and the customer is happy.
But sometimes i look at the bits in my van and think why do I carry all this for that 1 job every few months.
So what do you carry (not a full list dont think anyone has got time to go through everything in their vans)
Obviously I have all the usual 10/15/22/28 fittings end feed and compression I carry a lot of 1-1/4 solvent bits and over flow as the majority of my work is heating based.
What about spares? I carry a couple of gaskets Worcester, ideal, vaillant and an assortment of aavs and prvs then I always have a pump, 3 way valve, 2 port valve wired room stat etc etc but a lot of these are just sat on the van for months then I use them.
Same with traps I have an assortment of traps but they end up having the odd bit stolen off them then when I do need them I end up having to buy another. So do you hold traps, pan connectors etc? You can always guarantee if you take a bent pan connector you will need a space saver or if you take a straight you need an offset, which isn't a problem if your working 5-10 minutes from the merchants but if your 30 mins from the merchant it's a nightmare.
Morning Millsy,
I tend to keep flush and fill valve, a couple of pan connectors, some braided flexi hoses, 32mm & 40mm waste fittings, glue, plumbersmate, brass compression fittings etc.... the 2/3 port valves I'm not carrying with me neither the ch pump as I know in advance what my days look like. Definitely good practice is to keep so.e service stuff for various boilers.
Copper fittings , pipe , flexi hoses anything else i go get .
Never keep parts like 3 port valves.
Suppliers dont over stock as its expensive nor do i.
Besides i can charge another hour to go pick it up and have a cupppa whilst doing it
I cleared a lot of the stuff out yesterday. Because I had so much in there I could never find anything so ended up just going and buying more, I pulled 5 close coupled kits, 3 room stats, about 6 bottles of cleaner/inhibitor out of the van. 1 of the stats was from when I set myself up originally 5 years ago! I've now got a free shelf on my van!!!
When I used to work for a company I used to carry a couple of pumps a 3 way valve a Worcester fan etc etc but then I was doing 30-40 service/breakdowns a week so I would usually fit most of it within a month. Now I'm probably doing 30 service/breakdowns a month so the parts are sitting on the van for months on end.
Dont get me wrong its awesome when I walk in to a breakdown say your pump is shot and walk out an hour later with a happy customer and a bit more money in my pocket because I didnt have to go to the merchants. But I think I'm going to stop holding so much stock.
My garage is like that nabbed literally bundle upon bundle of copper when contracting , I still buy lengths lol.
I reckon I could crash the copper markets if o sold it all off
Reply to the thread, titled "Van stock how much do you carry?" which is posted in UK Plumbers Forums on Plumbers Forums.
Millsy 82,
hammers4spanner,
