ventilating chimney space around insulated liner
View the thread, titled "ventilating chimney space around insulated liner" which is posted in Oil and Solid Fuel Forum on UK Plumbers Forums.
Morning,
I'm planning chimney maintenance work in July. Its a stone chimney, cement rendered above the roofline with wood burner and stainless lined flue installed 8/9 years ago. There is no ventilation of the space in the chimney around the liner. Is there any reason why I shouldn't put a small vent just below the flaunching - sloped pipe to allow space to breath and help remove moisture. Presumably no matter how well flaunching is done there will always be some moisture getting in.
Previous owners of our cottage had a HETAS registered company put a flue liner in the large period chimney for a woodburner. They put an air brick in the side of the chimney above the roof line at the time. I assumed that was standard practice - as you say, it's preferable for the void between the liner and chimney to be ventilated.
....or remove a chimney brick or two in the loft space and back fill it with vermiculite if there isn't.
Two birds and that...
Reply to the thread, titled "ventilating chimney space around insulated liner" which is posted in Oil and Solid Fuel Forum on Plumbers Forums.
toucan,
toucan,
