Guest viewing is limited
Vertical flue slate roof
View the thread, titled "Vertical flue slate roof" which is posted in UK Plumbers Forums on UK Plumbers Forums.
GasmanxxxR1
Working on 1900 house with newish slate roof. I have all the proper ladders etc.
Anyone had experience using a pitch roof weather slate on a slate roof, anything to look out for.
It looks a bit fragile as do all slate roofs, customer said he has been up on it before
Cheers
The 'new' Brazilian slates are about as much use a Brazilian bikini !! When fixing solar panels, we usually have to replace 3 for each one we have to take out, at only £1.10 each (max) it's not really an issue of cost. Get a slates ripper and a slate cutter Toolstation > Hand Tools > Roofing Tools > Slaters Ripper you slide it up under the slate to rip out the nail holding it in from underneath (shear it through) then use these to hold the one slate that you can't fix back in when you flash around it.
Hall hook Slate Repair / Fixing: Amazon.co.uk: DIY & Tools
Genius Roof Solutions? | Hallhook? - The permanent, secret and fail safe device for replacing a broken slate
https://www.youtube.com/watch?v=134sVNOzn_w
Best roof flashing by a mile: Seldek
Seldeck? Didn't take you for a comedian!
I wish I could do this. I just paid £325 to have a vert flue installed! Quoted me £200 and then realised he couldn't hook his roof ladder over as no where to latch. Then no battens, only like feather edge so he had to strip tiles and use battens for a ladder. I was gutted. Big dent in me profit
get a better roofer we would pay 150
first time I went up on my slate roof, 150 years old via some scaffold, 1/2 way up roof a complete 20 x 20 foot section just slid off............ me on it !!!!!!!!!!!!!!! nail fatigue can be lethal, be careful up there 🙂
£150 will hire a decent tower scaffold for him to work from and allow you to remain a safety conscious main contractor, no subbie should use ladders for roof work, they arent safe.
Jeez Guys this use to be a plumbers job, what's going on, you be telling me next that the lead slate you bought is the wrong angle, what do you do then, bash the crap out of it!!
Go down to the local B&Q and seek out that man called "Steve the Plumber" and ask him to do it for you, most of those chaps have a few tales to tell, and that's where I will end up.
I have seen one of those slate rippers before, might be a good investment, cheers worcester
Bet you never use it again after this job, but it will look good hung in the shed next to the pipe bender, when your mate next door sees it, "What's That":thinking:
A slate ripper!!!!!!:50:
End of!!!
My mate Terry below with his band THE ARMY OF SKANKS.
Top roofer, though you wouldn't think.
And with his other band:
http://www.voodookings.co.uk/
First job he done for me, he arrived with a dirty great big fluorescent green mohican.
Reply to the thread, titled "Vertical flue slate roof" which is posted in UK Plumbers Forums on Plumbers Forums.
GasmanxxxR1,
wetdrip,
