J
johntwo
hi i have a glow worm hideaway boiler still working fine and never had any problems with it , but cause of its age im looking to replace it , its situated in the centre of house and flued vertically , does anyone know of a replacement free standing boiler that i can vertically flue . i can fit drain to outside behind kitchen cupboards and ill need to put in a 22mm gas pipe 15 mm in at present , any advice would be greatly appreciated .
im not doing the job myself just want to know if it can be done before i start ringing round . its an open vent system .
If its in the middle of the house there must be a wall to hang a boiler on.
vertical flue is is no problem
its situated in a small brick cupboard that originally had an oil fired boiler in and had its own brick built lined flue so i just want to flue the new boiler into that . the door into it is only about 4ft high then its just a small chamber 3ftx3ft up to ceiling height . difficult to work in .
Veissman and Worcester both do boilers suitable for use with a special chimney lining kit (C33).
You cannot use any boiler with a vertical flue as standard vertical flues are not intended for use inside a chimney.
Make your door bigger.
