Vertical radiator problem
View the thread, titled "Vertical radiator problem" which is posted in DIY Plumbing Advice on UK Plumbers Forums.
I have a vertical radiator with 5 sections. Four of the sections warm up ok but the fifth remains cold. The problem section is the end section on the left, the hot water flows in from the right. I have removed and flushed the radiator with no success. Any suggestions welcome.
has it ever worked if not have you fitted it the right way round some have a small dimple to let you know that that is the bottom of the rad,
It has never worked since I bought the house earlier this year. I will check for for a dimple or some indicator of the bottom when I return home on Monday.
Removed the rad yesterday. The baffle was located at the top which I guess confirms it had been fitted upside down. I reconfigured the rad, adjusted the wall brackets and it's now working fine. Thanks for your help.
Reply to the thread, titled "Vertical radiator problem" which is posted in DIY Plumbing Advice on Plumbers Forums.
Trev,
Gasmk1,
