Vitodens 100 intermittent heating water and radiators
View the thread, titled "Vitodens 100 intermittent heating water and radiators" which is posted in Bathroom Advice on UK Plumbers Forums.
skir2000
Hi everyone,
I am at my wits end here. Just moved into my new (10yrs old but new to me) house (and now I am broke :tounge_smile🙂 and have had intermittent problems with my Vitodens 100 gas boiler. I have a Siemens control unit to set the timer, as well as a thermostat in the hallway - I guess for adjusting the radiator temperature.
I have been using the boiler for just 6 weeks now solely for heating water on a timer, and as we move into the winter months, I now want to start using the radiators. However, when I turn on the rads, they don't heat up, but the water heats fine... Then, sometimes, the rads are ROASTING hot, but the water is cold - even though I haven't touched the controls.
Can someone please help me, am I doing something stupid, or do I need to get a repair guy out?
I am desperate here, and hoping for an easy solution - if its a repair job that's needed I will be having one heck of a cold winter 🙂
- The timer is set to turn on the central heating and the hot water
- I had the thermostat in the hallway set to 0, when I realised the rads weren't heating, I changed this a number of times, but no joy
- I have tried every combination on the timer, HW only, CH only and HW + CH - but still no joy
Thanks in advance,
skir
not showing in your google drive as of yet
there up and thanks and diy lash means its not a very neat/good install
right pressure is fine (should be around 1.2 bar cold and 2.5 hot)
can you answer this as you look underneath (boiler) are these pipes connected to anything in red
I think I understood you... added another picture of the bottom. the B and D pipes coming from bottom of the boiler are blanked off...?
thnx and that pic is great now the hunt begins you looking for something that looks like this will be one or the other
Found it behind the cylinder... That box, one pipe runs from the cylinder into the bottom, and the other pipe runs into the top of the red tank from my previous image... working on adding them all to one photo
(best when cold if pos) turn hot water off and then turn heating on only heating do you feel any warmth / flow through 1 on your pic? if you dont 80% the valves faulty
there fine see above comment quick q tho does pipe 1 just go to the red vessel or does it t off?
Damn, posted a comment but think I lost it... Added another 2 images to show you the cut off.
Also:
a: the pipe from the red vessel is cold
b: the pipe going from centre part of cylinder to the bottom (or #2) part of the box is barely warm
Now, when you said to turn on the CH only, I have a problem. Selected the unit to run CH only (using the +1hr button) and the boiler hasnt fired up. The display on control panel seems to think it has done its job, the red light to denote that the CH is on is glowing happily
Also:
i would say 3 port valve needs replacing
yes where you labeled 1 and 2 (1 is heating 2 is hot water)
OK... so from my image with the 1 and 2 on it
1. goes to red tank (expansion tank?)
2. goes to the cylinder
and then the 3rd part goes off into the wall somewhere... that correct?
Now, do I have a second problem with the actual controller? Heating won't switch on!
I added another 2 images - the boiler display shows no temp change and below that it doesn't show that boiler has fired up like the previous display images. As you can see in second image, the controller thinks CH is running. See the "BoilerNotFiring" images.
1 should go to the expansion tank and to the rads (should be a t somewhere on that pipe)
2 goes to your cylinder
3 is from your boiler supplying hot water
as for your controller press the red button it should change red column if not your controllers at fault and causing other issues
Thanks again, for the millionth time 🙂
I have been using the timer perferctly fine on the controller. The stat on the wall in the hall is what I changed. I used the +1hr function just to kick off CH on its own.
So if I need hot water, I run HW only. If I need hot radiators, I run CH only. If I need both, I assume I need to run both simultaneously? This is the issue I guess, why i need the valve replaced? Sometimes only one is heated when I have timer to bring on both...
if you have both on and yes thats is (both on either auto for a pre set time or manual on thats fine) and room stat or cylinder stat calling (needing heat eg cold) then yes valve would be the go to first
keep an eye on it for a week you might be fine now
what you need for boiler firing
heating side
heating - clock - room stat - motorized valve - boiler firing
hot water side
hot water - clock - cylinder stat - motorized valve - boiler firing
heating side
This has been extremely helpful!! I can't thank you enough, particularly for your patience.
Would you recommend that I keep the room stat on max all the time? Or does that use the temperature of the house to determine how long the boiler will run for? and just tops up the temp when needed?
Reply to the thread, titled "Vitodens 100 intermittent heating water and radiators" which is posted in Bathroom Advice on Plumbers Forums.
skir2000,
skir2000,
