M
markmonty
hi there i have a vokera linea 24 which has been working perfectly for years,now it has decided not to fire up, fault code 03 was showing , i then removed combustion chamber and boiler fired immediately and worked perfectly, when chamber is replaced boiler shuts down , im sure there must be a blockage somewhere but customer has lost book on boiler so i would b greatfull for any advice anyone could give mee, thankyou
Like many on here I could tell you straight away what that problem is, but before I do can you confirm if you're GSR?
yes im gas safe registerd since july this year, still finding out new things and trying to learn but as you can imagine im not very experienced in boiler faults yet, im thinking possibly a fan or air pressure switch but the boiler belongs to an old lady and i dont want to start throwing parts at it and costing her a fortune
Ive sent you a PM. If you contact one of the mods to get access to the Gas Safe Registered Plumbers section you will learn more from the guys. Unfortunately with Gas a little knowledge is dangerous.
yes i got your message,thankyou, its difficult just starting out, got to get hands dirty to learn but i wouldnt attempt anything that could b dangerous ,safety first all the time, thanks ces
2K
Boiler Advice Forum
Deleted member 120897
