Yeah that's the first thing I'm gonna do. I'm sure the diverter has been changed. I should be getting an email with a list of what has been changed.
I don't think they have changed the sensors, I think that's what they are planning on going back and doing but they are sending me first.I think they are losing confidence with the current company.Cheers for your help mate 🙂
Temp rise at flow rate? If no ... enough gas? Diverter passing? What temp diff am I getting across the phex? Is the burner staying on full rate or modulating?
With hot water running the display shows the temp of the hot water ... when you turn the tap off it reverts to the primary circuit temp! If my memory serves me right? 🙂
Sensors controls the gas rate, usually the first thing I'd swap to be honest....... By the way, just come to me .......... The control knob spindle can snap on these. It may be turned up to max but isn't actually turning the potentiometer on the pcb! If it snapped on minimum then the control stat could be stuck there! 🙂
Can you go into yhis differential manometer technique a little more? Do you put 2 tubes on the venturi?
me with a halsted something or other twas a right pain couldn't work out what the hell was going onI had this on a saunier duvall... bloody thing 🙁
Thanks guys. Never had to do this yet. I believe I can do this with my kane 455 kit can't I diamond? I remember you bought the kit the same time as me
Reply to the thread, titled "Vokera linear 24 Hot water issue" which is posted in Bathroom Advice on Plumbers Forums.
