Warm Air Systems
View the thread, titled "Warm Air Systems" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
PlumbersMate
Anyone know much about these? Went to a customers today, and the flow and return on cylinder werent getting hot so no hot water unless they use immersion. Cracked nut on the pipe and it was bone dry, thing that really got me was that there is no cold feed, f & e tank or vent pipe for the heating on their system, whole street is the same?! Do these systems not require them? If so what feeds the heating pipes?
Sorry if im being dumb here but ive never come across this in my life
was it a replacement cylinder? I'm thinking someone has maybe fit an indirect cylinder and done a runner 🙂. Do you know the model w/air or its circulator?
Think you're spot on mate. Her existing cylinder was leaking, so a fencer who also apparenty does plumbing replaced it with an indirect cylinder that is meant for pumped heating, I did say the cylinder is wrong type and that's when she dropped that bombshell and said she can't get hold of the bloke! Lol
ID...!!! if there's any water in the heater/pipework and it's turned on you've got a sealed time bomb !!!! I'd be back making sure the heater is disconnected or the cylinder is replaced!
Problem solved. Another fk up by a wanna be plumber who knows nothing. No more than she deserves as she knew he was a fencer (probably a ganger). Like going to the fishmonger to get a tooth out :lol:
Yeh I switched the boiler off before I left and told her not to use it until she called out her boiler manufacture engineer as the boiler has been declared at risk by British Gas anyway but scary thought is she has had that switched on all week!
Also to answer you before the model is a Johnson amd Starley j25-32 mk 3 . She showed me first plumbers business card and it said fencing and gardening, and then on the back it said I'm also a water qualified plumber??!! I asked her why on earth you would use someone like that and she said I've learnt my lesson now!
If ever there was a potential RIDDOR reportable job I'd imagine HSE would be interested in this one?
I doubt it Diamond. Worst case scenario a split pipe. Not enough volume of water.
Warm air units are simple to work on if you are qualified (a full 4 questions and another £80 on your acs) and they work very well. Just not to everyone's taste or liking. The guy changing the cylinder doesn't need to be qualified or registered with anyone. Nothing to do with gas safe. No amount of regulation can cover the idiots tho.
When they started putting qualified for vented cylinders on the gas cards ( i wonder how they knew i was, i certainly never told them???) i thought what is this all about. Basic stuff learned from day 1 but how times have changed when even the basics are not understood. Sometimes the way the trade is going actually depresses me!
Time for a wee JW green label😛arty3:
your most likely right tamz regards the RIDDOR! Are folk not taught about the simplest of system designs such as direct cylinders though!
I'm joining you mate, I'm on something a bit softer though Red Wine 🙂
Now on the Dalmore 15 but the green label was better. Might break out my last alligator later. The bride has retired for the night full of the sangria but she has an early rise making my sunday fry up in the morning:lol:
I think they are taught very little about anything these days. My apprentice is in his final year doing svq3 and is absolutely clueless regards systems. It does my t!ts in. God knows what the future holds when all the "old school" rap it in.
Aye!! It would irritate me if i had to explain gravity circulation or open systems ... One pipe and two pipe design etc ... I think its in the best interest of all in this industry to grow in knowledge of the things we work with! I'll never work on solar thermal but still feel the need to understand its concepts for example 🙂
A bit late replying to this one, but have come across it before.
As long as the water heater and warm air can be safely used, you can install an expansion tank in the loft and connect open vent and cold feed as in old gravity system to the cylinder flow and return.
Kev.
Reply to the thread, titled "Warm Air Systems" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
PlumbersMate,
Kev the gas,
