View the thread, titled "Washer and dryer under stairs" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
To be honest, I wouldn't put a a condenser-dryer anywhere in a house that I owned. 🙂
Anything is 'possible' but it might be expensive to get the necessary drainage and power to the location. You'd need to get a quote from a plumber and electrical to know how much it will cost in your circumstances. You might need to reinforce the floor depending on its construction.
I wouldn't put white goods under a staircase because they are a potential source of ignition and stairs are a fire exit route. Also, if you want to run the the machines at night to take advantage of lower-cost electricity there is a noise issue. Even if you consider these downsides to be acceptable, a future buyer of the property may well not. (I suspect it would be unlawful to rent out a property with white goods under the stairs but you'd need to check that with someone who knows more about landlord's duties than I do.)
IMO, the right place for washing machines, etc. is in a ground floor kitchen or utility room. Preferably, on a concrete floor or on a reinforced area if it's suspended.
It’s interesting that you say this and I agree.
But many houses in USA have the laundry upstairs for convenience of that’s where clothes are put on/ taken off/ stored. And they are often dried by machine - rather than us brits drying outdoors.
And other countries have them in the bathroom.
Reply to the thread, titled "Washer and dryer under stairs" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
Thread starter
Joined
Location
Staffordshire
DIY or Homeowner
Thread Information
Title
Prefix
N/A
Forum
Start date
Last reply date
Unsolved
Thread Tags
Tags Tags
None
AlisonGarner,
Ben-gee,
