View the thread, titled "washing machine" which is posted in UK Plumbers Forums on UK Plumbers Forums.
pauls
anyone know anything about washing machines a customer phoned, i dont want to turn her away even if i turn up and confirm an engineer is needed i need every customer i can at the moment.
problem is the washing machine wont drain, anyone got any ideas
underneath the machine is the drain pump, remove the flexible hose from machine, lower it to floor level in a bucket, most water will drain out. locate pump remove from wmachine, it will have toothpicks, clothes pegs, or something weird blocking the impellers.
You should be able to remove only pump head with impeller and motor attached,if all clear just replace pump head
Ok gents but where do we get the pumps for the washing machines? I have just spent £80 getting mine repaired! And the cheek of it the misses blamed me 😕
Ok so there was a few washers,screws & rawplugs, the good news was they also found £5 in change 😀
then it only cost sevetyfive pounds and its her fault for not checking your pockets properly
You might be a bit short of cash Winston, but money laundering as well as Plumbing? 🙂 🙂
got it sorted mingo was spot on took pump out and a screw was rattling about in with the impeller😀
im happy cos ive gained a customer and customer happy she has washing machine fixed😀
Reply to the thread, titled "washing machine" which is posted in UK Plumbers Forums on Electricians Forums.
