Waste pipe connection from basin
View the thread, titled "Waste pipe connection from basin" which is posted in DIY Plumbing Advice on UK Plumbers Forums.
DIYAlex
I have a bathroom basin that had a flexible waste pipe leading from the sink into a fixed waste water pipe. The Flexi-pipe had perished away and I can not find a replacement to fix onto the basin to the waste pipe. I have tried numerous flex pipes but none fit onto both.
Im probably being stupid so excuse the dumb question but would appreciate any help?
Question isn't stupid. Assuming you're in UK, you'll find flexible waste pipes easily enough. What you would normally have is a 'basin trap', a bit of pipe coming out of that, and you'd connect between the pipe leaving the P or S trap with the flexible bit. I'm not saying a flexible connexion is the best way forward, but may suit your circumstances, and if it worked before...
It sounds like your existing setup may be a bit odd. Photos?
Reply to the thread, titled "Waste pipe connection from basin" which is posted in DIY Plumbing Advice on Plumbers Forums.
DIYAlex,
Ric2013,
