View the thread, titled "waste pipe debuurer" which is posted in UK Plumbers Forums on UK Plumbers Forums.
E
elkay16
Wondered if any one could recommend a tool that chamfers/deburrs waste pipes of both 32mm and 40mm. i used to have one that was shaped similar to a heart with an internal blade and recesses to accept both sizes. now all i seem to be able to find are ones for each individual pipe size
Any help would be much appreciated
Sounds a bit of a gimmick to me. Another one trick pony that would clog up the tool bag & go missing when you need it.
A Stanley knife does the job every bit a well & has many other uses too
think theres a pipe deburring tool in toolstation or screwfix, i have one, hardly use it. i find running fingers around edge does fine, might add thats solvent weld pipe, pushfit different
You can get a deburring tool that looks like a pipeslice with an arrowhead type blade. Seen them but never found the need for one. ABS or MU use your fingers poly use the edge of a halfround file.
I carry a lathe in the back of the van which I get out when needed to give me a nice finish 😀
Get a 1/2 round (Good Quality) file its a must have in a plumbers toolbag. It will deburr all sizes of pipes and has many other uses.
"has many other uses"
Like pulling the upstand pipe off a side entry immersion when fitting a sidewinder?
Oops. Showing my age 😀
thanks for all replies
i appreciate what you say about file, knifes etc but this tool was so damn good, juts a couple of turns and your pipe was deburred evenly on inner and outer edge.
many thanks anyway
Reply to the thread, titled "waste pipe debuurer" which is posted in UK Plumbers Forums on Plumbers Forums.
