View the thread, titled "Water dribble when soldering" which is posted in UK Plumbers Forums on UK Plumbers Forums.
I'm a complete notice and I working on my heatings motorised valves on my S plan system. I was modifying the system to add an arrester. Long story short, I made a bodge of the soldering due to persistent tiny water dribbling in the pipe being soldered which I overlooked despite the system being drained. How does one get around this? I heard of people using bread but that won't work here I won't be able to retrieve anything from the pipe afterwards.
Using bread is fine as it just dissolves in the water when filling so you dont need to remove. You don’t need t use a full loaf though just enough to soak it up to stop the drip. But failing that as already stated use compression
Or press fit.
Or get a small bore hose, insert in to pipe and blow/suck the dribble, then solder quick before it comes back.
Or open a drain off/compression near by to divert the drip.
Reply to the thread, titled "Water dribble when soldering" which is posted in UK Plumbers Forums on Plumbers Forums.
Thread starter
Joined
Location
Ireland
DIY or Homeowner
Business Name
x
Thread Information
Title
Prefix
N/A
Forum
UK Plumbers Forums
Start date
Last reply date
Unsolved
Thread Tags
Tags Tags
water
red_rover,
Timmy D,
