View the thread, titled "water dripping through kitchen ceiling" which is posted in Bathroom Advice on UK Plumbers Forums.
L
leawell
Intermittent water dripping from kitchen ceiling and overflow from bathroom (bath only) above. All water pipes and surrounding areas in bathroom, toilet and water tank appear dry and undamaged. What is the possible cause of the problem, what is involved to fix it?
If intermittent would suggest waste system leaking
First thing would check bath over flow fitting, through bath, they come loose and drop down slightly, leak when water splashed ,other wise ok
Had the same thing but seeing how I only have a bath twice a year,it was not so much of an issue ;-)
imho
If you've a shower over your bath it might be worth checking that the sealant around the bath isn't failing and letting water through beforee looking for more complicated causes.
Reply to the thread, titled "water dripping through kitchen ceiling" which is posted in Bathroom Advice on Plumbers Forums.
