The remodelling work I did a few weeks ago involved a complete drain-down and from calculating the amount of system water (using the different expansion level heights at two given temperatures) I see that I now have around 200l of which I understand up to 17% by volume could be entrained air. If all that was released then, eventually, up to 30l of air might find its way into the tops of rads and awkward legs of pipework requiring a significant amount of bleeding off. A rough calc. suggests that a 3m head from the pump might be enough to displace the kind of amounts of water seen in the F&E tank even if only a few litres of air was spread around the system.
Also, I've been able to get a much better idea of what's going on in the vent pipe after getting my old FLIR camera working on my phone again (a new phone with USB C which needed an adaptor - the first one I bought didn't work but I've now managed to find one that's compatible).
So on the left it's showing the level in the vent pipe with the pump on, then on the right, maybe a 1cm rise when not pumping. This is similar to what it looks like in the F&E tank so the displacement isn't into the vent but the general level in the system goes down when under pump pressure.
