Water flowing through vent pipe over F&E tank.
View the thread, titled "Water flowing through vent pipe over F&E tank." which is posted in UK Plumbers Forums on UK Plumbers Forums.
I recently took off an end stop on the vent/expansion pipe over the heating header tank. I now know why it was capped off. When the 2 way valve opens to heat the hot water, water pours out of the vent pipe. I had a heating engineer out, he said get rid, open vented systems are now obsolete, failing that, cap off the pipe again. That great 2minute advise cost me £40. So, I've checked a lot of advice on here, and firstly the whole system is 22mm pipework, except for the vent pipe which is 15mm, should this be 22mm as well. The cold feed goes to the top of the heating coil in the HW tank comes out at the bottom 2metres of pipework, then a tee to the vent pipe, then the 2 way valve. Then I guess, to the boiler in a detached garage with hidden pipework, a nightmare to chase. I can't find anywhere with this layout of feed and vent and wonder if anyone has any advice as I can't afford a new boiler and sealed system. My boiler does have an overheat thermostat, so the blocked vent is probably not dangerous.
Old gravity set up the heating system needs sealing / pressurising
I'm not a plumber or heating engineer, I don't know what you mean by sealing. Does that mean it's OK to close off the vent pipe, which would mean effectively it's sealed
No need a heating engineer to seal the system for you eg expansion vessel filling loop etc
So, sorry for my ignorance, but how has it operated all these years as it stands. It all works fine unless I take that end stop off what I thought was the vent.
It still expands through the feed so the tank water still rises so needs sorting
If the cold feed is 22mm and has .no isolation valve then a vent is not required as far as I know.
Hi
Hi if you have a expansion pipe if must open and bend into F/E tank it’s the safety valve it’s the last resort if all controls fail and boiler overheats and goes towards boiling
Reply to the thread, titled "Water flowing through vent pipe over F&E tank." which is posted in UK Plumbers Forums on Plumbers Forums.
Telboy24,
andyburke,
