Sep 27, 2021
18
UK
DIY or Homeowner
Hello everyone. Minor issue I'd like to try and adjust before I call a plumber back out. I have mains water to the kitchen and to the water tank in the loft.
3 weeks following having a kitchen tap fitted by a plumber I was running a bath suddenly there was this loud pipe/plumbing noise and the water turned brown. I called out the same plumber again and he said it was the ballcock in the water tank bouncing causing the valve to stop/start. There was also some sediment hence the brown water. This he said was due to an increase of pressure from the way he left the mains kitchen valve open. Previously he'd found it locked tight and had to use a tool to loosen it so left it with a tiny amount of slack(had also tried street isolation valve, but that was filled with debris). To resolve the water tank issue he adjusted the mains isolation valve in the loft and that stopped it.
Now 2 months later I'm getting the same thing, but not as bad, but its still noticeable and concering. So having seen the problem in action last time I was thinking of looking to to adjust the mains valve in the loft myself and seeing if anything on the ball cock can be adjusted.
Firstly though should I have any concerns? The whole thing was working fine until the tap was replaced and its concerning that a tiny change in the position of one valve can cause this. I mean is there an issue with the tanks ballcock or something else? Also If I'm looking to adjust the mains valve in the loft should I be opening or closing it more to decrease the pressure?
Hmmm tested it today and it's happened again. Don't think I've reduced the flow that much as when I push the ballcock down a torrent comes out. I've try closing the valve more, but I think time for a plumber to do as suggested by yourselves.
Regarding the water hammer and the ball valve "bouncing", you use to be able to get equilibrium ballvalves, which stopped this, as the valve had a hole through its body which "equilised" the pressure on both sides, so stopped the bouncing. So that might be an option? Also the side walls on plastic tanks can flex, which can also cause water hammer / bouncing, so an old trick was to place a thin sheet of metal plate behind the valve assembly, with a suitable hole so the valve thread would go through it, (on the outside of the tank) which would reinforce the plastic tank wall, thus reducing any flex, etc.
Hope you get it sorted, cheers...
No, if you bend it downwards you will have a few litres less in the storage tank, if you bend it upwards water might start overflowing.
Reactions: exedon2
Fun and games. While waiting for the plumber due soon it's stopped oscillating even when I run the taps for ages. Valve is open half way and only change I can think of is a temperature change with the winter coming in and heating being used. So annoying.
Plumber came out and not so happy with the work. I didn't get the valve as suggested here and let them supply one. They turned up they had was the wrong size valve and went to get another one. Basically they've replaced the valve with one that looks identical which after posting on here is a surprise. Noticed the water level was lower now, but no boucing ballcock so good there. However now when the bath runs you hear a strained noise coming from the valve which has an affect to act like water hammer. It also dribbles for ages when it's filling back up. Groan.
