View the thread, titled "Water leak from HWSC" which is posted in Bathroom Advice on UK Plumbers Forums.
C
chers
Hello all
I was called out yesterday to a water leak coming through a ceiling,it turned out to be the HWSC in the hotpress above.There is a constant trickle of water from the primary flow where at its joint with the essex flange.I have advised customer that as the cylinder is around 30 years old that a replacement is required however she is considering a combi boiler therefore no need for a cylinder.
I have been asked to do a temporary repair on the cylinder in the meantime.Question is can anyone recommend a sealant/putty that can be applied sucessfully over a wet joint ?
You can get two part epoxy resin puttys. Cost two quid a roll from Tool Station. I've never used it to solve a leak, but it does appear in the plumbing section of the catalogue so it may be used for that.
I use it if I need to fill a hole, let it set and redrill it. The stuff goes bullet hard after about 5 minutes.
Thanks Dannypipe
I was thinking something like epoxy putty might work.If something would work without draining down it would be great although it might be a big ask.i I searched the net and came across one called "No nonsense external leak sealer" 50g tube,it claims to seal up joints even when wet . Ever used/heard of it ? or anyone that has ?
I have used the epoxt stuff once with great success, just make sure you use a knife and really push it into the joint. It's not what you see outside that's important it's getting it into that joint.
Good luck mate.
Think im gonna try the epoxy putty,do you think it would work while the joint is wet or would it have to be drained down,dried off and allowed to set/harden ?
Reply to the thread, titled "Water leak from HWSC" which is posted in Bathroom Advice on Plumbers Forums.
