View the thread, titled "Water leak outside property" which is posted in DIY Plumbing Advice on UK Plumbers Forums.
Not exactly a plumbing problem but here goes. I have known for a couple of years there was a water leak somewhere between the water meter, on our property, and the property itself. The water company fitted a new (smart) meter about 4 weeks ago. Now they have contacted us saying we have a leak as we are using water 24/7. They say we should fix it giving a deadline or they will fix it. Not sure how that works as they would need access to the grounds. Anyway I digress. The leak is most definitely on the external pipework because even with the stopcock closed the meter still goes around, well the old one did not bothered to look at the new one yet. So what all this waffle is about is there a way to find out where the leak is occurring. I know at some point there is a 'T' joint off to an outbuilding. I am aussuming that the leak is at a fitting and not on the pipe itself. So we have exiting the meter or the 'T' joint. I have not got a clue as to how to ascertain where the 'T' joint is. Also unsure as to how reputable somebody might be who says they can fix it. The distance from the meter to the stopcock is some 40m which I do not fancy digging up.
Any suggestions gratefully received.
There are techniques such as thermal imaging, acoustic measurement, electrical sensing and tiny cameras that can be fed inside the pipe, and sometimes the use of dye. I'm not sure how effective thermal imaging might be at this time of year! You could ask a company who specialise in this stuff to find the source of the leak on a 'no find - no fee' basis. I think you just have to grit your teeth, find a professional outfit, and pay the money!
I don't know how reliable the summary figures below are. No harm in seeking a quote?
Mabe someone on here has a suggestion of a reliable company to ask?
Might be worth shutting off the stop tap internally and take a meter reading and leave it over night shut and take another reading in the morning eg next day
Can I respectfully ask why as I know the leak is somewhere between meter and property?
If your 1000% sure then only option is either a tracer gas to re lay the whole line if the tracer gas can’t find it as you will be billed either for wastage of water or to re do the length from there contractor
I am a bit between the devil and the proverbial deep blue sea. I need to have a look at my insurance policy but knowing my luck will not be included. Think I will start by digging up at the meter seeing if the outlet connection is ok. Next will be the end of the 'T'
section outside the outbuilding it feeds, as it enters here on 15mm copper so somewher is a change from mpde to copper. If I get no joy will bite the bullet and get some 'expert' in.
Might be worth to start pressure testing in sections least you know which bit it would be on etc
What is the surface of the route from meter to stopcock?
By which I mean; tarmac, slabs, grass concrete etc etc.
Approximately 35m soil and gravel top remaing 7/8m is patio slabs. I did have a though that if I could expose the pipework in a few places, easier said than done mind, is it possible to hire a freezing machine suitable for mpde in that way I could isolate sections as suggested previously?
So no tell tale “lush grass “ areas!
How far away is outbuilding?
Is pipe mdpe or old galvanised?
Mdpe from meter to house but somewhere it changes to 15mm copper before entering outbuilding. No signs of moisture anytime in summer so no clues there. Have got a guy to come round next week and do a bit of digging so we will see,
You don't need to freeze MDPE, use a squeeze off tool
You'll probably find it cheaper if you search, or make one yourself
The squeeze off tool has round jaws and the pipe has some memory and will recover from being squashed.
Leak could be anywhere from the junction onwards, how deep is it buried ?
Good question. Was meant to have a guy around today to dig some holes. He has Covid and his wife was made redundant yesterday hence reason for his non appearance. I will dig a few myself and see where that leads me. I think in this freezing weather I would be tempted to warm the pipe up a bit before I started squeezing it. £26 off *bay so worth a punt at that.
And while I am it I looked at slip couplings the price does seem to vary enormously for the same thing.
MDPE Water Pipe Repair Slip Coupling 7610 - Water Pipe Fittings | Drainage Central - https://www.drainagecentral.co.uk/MDPE-Water-Pipe-Repair-Slip-Coupling-7610 £19
Plasson Universal Slip Repair Coupling 31-35 X 31-35mm 176100031035 - https://www.cityplumbing.co.uk/p/plasson-universal-slip-repair-coupling-31-35-x-31-35mm-176100031035/p/898884 £46
Am Imissing something obvious?
Both made by Plasson apart from colour is there any other difference?
Yes as Shaun says, the first fitting you have to buy in the specific size you need, the second is a different design of seal that fits a range of sizes 31 to 35mm. The first doesn't have flexibity for slightly different size pipes. I believe it's a more complicated product hence a higher price.
The first one is a size specific slip coupling only for mdpe pipe.
The more expensive one is designed to deal with different pipes eg galvanised or whatever you might come across with that diameter.
In your case you only need the mdpe plasson coupler.
Just received the squeeze off tool. Not sure why I thought it would be much bigger than it is, quite dinky. All I need to do now
is get bup the courage to go outside and dig a few holes in this damned cold weather. Tomorrow sounds a good idea.
Right an update. Dug out a few holes and found a T piece outside where the water enters the property. I knew there had to be a T somewhere as supply also feeds an outbuilding. Now the pipe is black 3/4inch MDPE and the T piece is an equal brass
compression fitting. As far as I can see 3/4in brass compression are classed as Irish pipe fittings, must be something to do with the Guiness.
So my intention is to remove the T piece and use a stop end at the incoming supply end of the T. That will let me determine whether the leak is between the T and the meter or not. I thought this might be less harmful to the pipe than using the squeeze tool I have just bought. Any thoughts?
So bit the bullet and used the squeeze off tool. Was hesitant as to if it would damage the pipe, I need not have worried. Warmed the pipe up a bit with a heat gun and it shut the water flow off a treat. Took it off and put back on at 90deg to previous position to get rig of the slight kink in the pipe. Is now fully round. Least it has shown me which leg the leak is on. Luckily the one going across a lawn, about 10m, and not from the meter to the house about 35 m. So only have to mess around doing holes on 10m worth.
Reply to the thread, titled "Water leak outside property" which is posted in DIY Plumbing Advice on Plumbers Forums.
Thread starter
Joined
Location
Norfolk
DIY or Homeowner
Thread Information
Title
Prefix
N/A
Forum
DIY Plumbing Advice
Start date
Last reply date
Unsolved
Thread Tags
Tags Tags
leak water
Bogart,
Bogart,
