Water main sizing advice please
View the thread, titled "Water main sizing advice please" which is posted in Bathroom Advice on UK Plumbers Forums.
I have recently moved to a farmhouse in central Scotland and the other day our closest neighbour accidentally burst our water main with a JCB. The main is a 1” MDPE pipe running about 500m from the water company roadside main to our farmhouse. This was installed about 20 years ago. The farmhouse is perhaps 5-6m lower than the point it connects to the water company main but our house is on two floors so the upper floor is around 3m above ground level. We have a ground source heat pump with unvented cylinder so we can’t use a shower pump and our water tank is downstairs.
My neighbour, who is a builder and architect has decided to take a branch from my pipe while doing the repair, so that he can feed a house that he is refurbishing. His branch is coming from an equal T piece so is also 1”. He says it should not affect my pressure/flow because you can feed 3 houses from a 1” pipe.
So, my question is, should I be concerned about this or am I worrying about nothing? His branch point is around 80m from the roadside mains supply and my house is around another 500m downstream and like I said 5-6m lower than his house.
Obviously I don’t want to fall out with my neighbour having only just met, but it’s going to be much more awkward if every time someone turns on a tap at his house my supply stops!
Advice most welcome!
Thanks,
Craig.
Reply to the thread, titled "Water main sizing advice please" which is posted in Bathroom Advice on Plumbers Forums.
Craig Chamberlain,
AWheating,
