Discuss Water Pressure In..Washing Machine in the Ireland area at PlumbersForums.net
The water in to my washing machine is via a tee off the cold water mains via 1/2" PEX pipe (2metres) and then the washing machine hose connected. The water pressure into the machine seems very low. The water pressure on the kitchen tap is really strong. Why would this be, I would expect it should be the same.
It is causing an alarm on my washing machine re. low water pressure in. Any ideas/suggestions
The tee, is it an appliance/washing machine tee? If so, could be a stuck ball. Try disconnecting the hose from machine and test into a bucket, or something similar. If that’s poor, then it’s before the machine obviously. If that’s strong then could be the hose is kinked when pushing it back, or blocked filter.
Reply to Water Pressure In..Washing Machine in the Ireland area at PlumbersForums.net
We have a utility room with a washing machine but no sink. Wife wants sink. There is room to fit one and the waste will connect to wahing machine...
Hi, We have noticed for a while now that when our washing machine nears the end of a cycle we get a bad smell of dirty water in the downstairs...
This is the only place I can fit a washing machine in my new kitchen. The drainage pipe would have to go approx. 5 m - is this okay or will it...
Hello, I'm installing a new kitchen which will have a dishwasher and washing machine. As I'm cutting/teeing into the cold mains 15mm pipe (before...
Hi, all. I have a leak problem behind the washing machine. It's a pipe that is leaking directly into a drain. It used to drip but now is leaking a...
Pritesh Patel
