View the thread, titled "Water pressure" which is posted in Bathroom Advice on UK Plumbers Forums.
L
leslie50
Hi have been working on a bathroom,and there pressure hot and cold is useless ,it is a bungalow , with a gravity fed system , the cold in the bathroom is all run from the tank, hot from copper tank, it has concreat floors throughout , looked in the loft and there is no way the tank can be moved up , is there a way to increase the pressure,apart from running it all off the mains.
Regards
Leslie
Aye, as Gray said, get a plumber in. You need a whole house pump. You need to know where you're gonna site it and whether you'll need a positive or negative head pump.
Reply to the thread, titled "Water pressure" which is posted in Bathroom Advice on Plumbers Forums.
