View the thread, titled "water pressure" which is posted in Bathroom Advice on UK Plumbers Forums.
scoop321
What is the average water pressure into a house from a boundary tap? I've only got 2bar
when you turn the hot tap on it's only a gentle flow, but if you turn the cold on at the same time the hot stops. so there's not enough pressure to run both taps.
is it just in the kitchen or do you get the same results in the bathroom? also what kind of tap is it? and are there any restrictions like flexi connectors or isolation valves because these will restrict your flow rate
Reply to the thread, titled "water pressure" which is posted in Bathroom Advice on Plumbers Forums.
