Water usage calculations.
View the thread, titled "Water usage calculations." which is posted in USA Plumbers Advice on UK Plumbers Forums.
Chalked
local council planning officer is asking for a water usage calculation on a large house.
6 shower rooms, 2 bathrooms, 3 cloakrooms. 4 outside taps, 2 kitchens and 1 utility.
Oh and a pool.
Do they want peak usage, adding all outlets at once? There’s only 4 people live there!
Do you know @ShaunCorbs .?
I've seen as usage chart somewhere. Maybe in the building regs which give the max required and then you are down to guessing something just under.
Long time since I have done it though.
The alcohol has killed off a lot off the grey matter since then.
Reply to the thread, titled "Water usage calculations." which is posted in USA Plumbers Advice on Plumbers Forums.
Chalked,
jtsplumbing,
