saaf
Morning all.
I have just moved in to a new place with a basement bathroom and have a WC problem I'm hoping someone has seen before and can offer advice on.
The problem I have is that the WC doesn't flush well enough to clear waste (both paper and #2s), requiring a bucket of water to do the trick.
The set up is that the WC has a concealed Thomas Dudley 6l Pushflow (I think) cistern (pneumatic flush design), N&C Olympus toilet and a Grundfos wc-3 macerator. The latter is connected to the WC, shower and basin. Both the cistern and macerator seem to work fine, and the whole setup was new early last year and has had relatively little use (it's a 2nd bathroom).
My best guess is that the problem is that the toilet bowl design isn't suitable for the setup - i.e. the 6l flush is too diffused by the rim design to be effective. Or perhaps it requires a siphon effect that isn't possible with a macerator? Another possibility might be that the macerator impedes the outflow from the WC (although the water level doesn't appear to rise in the bowl).
Any ideas? Have you seen this issue before?
If it is likely to be the bowl, can anyone offer recommendations on WC makes to look out for that work better with the combination of 6l flush and macerator? I might add the WC is floor mounted and flush to the wall, with cistern and macerator behind.
Many thanks.
Thanks Steve. Is it your experience that this issue is more problematic with macerators?
My view is that unless the system always works first time the smaller cistern is a false economy. E.g. our other WC had a 'hippo' device in the cistern that meant 8/10 times a second flush was required, with the result that it probably used 30% more water than without the hippo.
Grateful for other views/insights.
Cheers.
In my case the pan is pretty much in 'as new' condition, so I am confident that is not the issue.
the fact it works when you flush using the bucket seems to indicate that 6l is not enough
I am not familiar with your model of pan but I have had to change a couple of pans with the same problem because the opening in the base of the pan is too wide try and have a look
at your plumbers merchants stock to see if you can see any pans with smaller openings also double check the level in your w.c cistern😱regards turnpin
