Weather compensator for Firebird Oil Boiler?
View the thread, titled "Weather compensator for Firebird Oil Boiler?" which is posted in Boiler Advice Forum on UK Plumbers Forums.
I have a space heat only 26kw output Firebird Condensing oil boiler. I only use it for my homes space heating nothing else. Well insulated 80s renovated home.
You can see there the boiler temperature stat is the simple white box.
I recall about 10 years ago there used to be generic weather compensator you could install to any home. But searching now all I can see are ones meant for a specific boiler. Eg Worchester gas boiler.
Can anyone advise on a simple weather compensator I may be able to fit here with an external temperature sensor to enable auto adjustment of the boiler flow temps VS the outside weather?
Won’t work as it can’t communicate with the boiler you can’t wc fully an oil boiler as there’s no brain also no modulation would need to change the boiler to something like a navien or Viessmann
On finding the instructions for this, attached I think it is a main programmer and takes the inputs of the sensors which you buy from them. eg, boiler pipe sensors and exterior / room sensors. It has a number of settings also per the manual.
Not saying it's ideal but may be one of the few options to weather compensate a std oil boiler. It would maintain the independant time & temp zone control I have too. But would like to check is it simple to boost because I generally dont time all zones each day as alot of the time we are both working late.
It's also not a smart controller so no wi fi funtionality. I will send them a number of Qs I have and also research more on other alternatives. I think being able to auto control the boiler flow temps comensurate with the exterior weather could equate to a decent efficiency gain - in particular in the milder autumn season etc.
I could also settle on just manually adjusting the boiler temp myself - just want to explore what options there are.
Reply to the thread, titled "Weather compensator for Firebird Oil Boiler?" which is posted in Boiler Advice Forum on Plumbers Forums.
JC22024,
JC22024,
