Weird hot water issue
View the thread, titled "Weird hot water issue" which is posted in Bathroom Advice on UK Plumbers Forums.
Riley
Subscribed
Scratching my head a bit with this one. I don’t know if anybody has come across this before. Bath in a property has very basic nonceramic taps when she runs h & c, hot runs cold after about 10 mins. It’s off a combi boiler sonoy a lack of water. When she run just the hot tap it runs continuously hot.
Hope somebody might be able to offer a pearl
Ha ha agreed. Tenant is not bad to be fair, pretty switched on but can’t really remember the previous taps as they were changed literally the day after they moved in. I think New taps it is
Ha ha it’s a valid point and may well be worth I try. It just seemed so odd that tap runs for 10-15 mins then goes Stone cold
Yeah and the boiler continues to fire. It’s almost as if the hot water is diverting elsewhere but it’s not
The heat must be going somewhere. Are you sure the rads aren't getting hot (whether you want them to or not) when the hot runs cold? Might be problem with the 3-port valve in the boiler. I would switch it to hot water only mode and see if it happens, and if the boiler continues to fire if it does.
My son has a combi (Vaillant if I remember right) which was behaving oddly, not unlike your symptoms. They said it was an uncommon but known fault, and replaced the valve under warranty. Been OK since.
Sounds like you have discovered a new law of thermodynamics 😛
Ha ha perhaps I have, the only thing changed there is the taps, from speaking to the last tenant there was never a problem since they’ve put these ones on with a much greater flow there has been a problem. There’s no other logic to it unfortunately
Right, update. Changed to quarter turn pillar bath mixer tap maximum 9 lpm maximum and the problem has gone. I cannot see what the reduced lpm would have done but it seems to have done the trick.
Thanks all for your thoughts it remains a head scratcher
Not for the first time, I was wrong! Good that you've cracked it.
You are welcome mate. Taps are a weird thing sometimes.
As I say though mate doesn’t affect any other outlet. Kitchen sink buckets out hot, basin buckets out hot. LL didn’t want floors up to check pipework etc so taps was his cheap fix. As I say just a mystery that hot would just cut out from the tap after 10-15 mins
It's one of those pita faults 😀
Reply to the thread, titled "Weird hot water issue" which is posted in Bathroom Advice on Plumbers Forums.
Riley,
Riley,
