View the thread, titled "well water supply" which is posted in Bathroom Advice on UK Plumbers Forums.
water supply from well wont reach top of 2 story house,
looking to fit potablewater cistern at ground level outside, shed to be built over after
need pump at ground level cistern to pump water to storage cistern in loft space working with flow?pressure switch?
feed into ground level cistern through in line filter, uv also to be fitted
help please? any site to go on?
cheers
cheers
Grundfos pumps
Lowara pumps
Jung Pumpen
Dab pumps
Probably in that order.
Reading through the post again wont a well booster pump from Grundfos or Lowara be better then just go from well to loft. Not being a plumber I`ve probaly missed something though so please no shouting at me.
Would of thought a good 12 or 15 stage booster pump will do the required head but need to talk to the tech people regarding the flow rate and pressure at the outlet of course and the other stuff like filters.
Get your kids buckets then! When i was young we had to walk 1 mile to get water to heat up to wash the dishes so we could then start to think about breakfast?
What is the distance from the top of the well to the top of the water?
Need that information before you get your answer!
Would also be good to know the distance from water level to bottom of well
You were lucky! We lived under a tarpaulin in a hole in t'middle 'o t'road, got up half an hour before we went to bed, sucked the moisture from a dead rat for breakfast and went to work down t'mine for 26 hours a day for sixpence a fortnight.
You had a dead rat! Now you were posh ! We had some sheep poo entangled straggles off the barbs . And that was a joint prezzie for all. 19 of us. Who lived in the mine but worked in the sewers.
Reply to the thread, titled "well water supply" which is posted in Bathroom Advice on Plumbers Forums.
