What a nightmare in my eyes...
View the thread, titled "What a nightmare in my eyes..." which is posted in UK Plumbers Forums on UK Plumbers Forums.
I heard o lot when having a water meter you will need a shock arrestor that's what the Worcester have said due to the non return
Have you paid?
Maybe request a free gas safe inspection
Yes have paid already in full and he keeps asking me to leave him a review. It I will explain to him today ( as I am not a pick ) that is not what he really wants as it will ruin his business.
I actually wanted to ask him for a gas safe check for another £75 and perhaps changing the gas hob.
Perhaps I won't be offering money but instead asking for doing it for free. I know what his answer will be and how he will react towards me 🙂
He's not working on the gas line
If he was replacing the gas valve he would only have to test from the boiler valve to the new gas valve
I was still happy with the way he checked and worked at the boiler but the aftercare ... don't ask me ... never again ... learned the hard way again!!!
Did the Worcester guy screw down the flue or leave it?
After I mentioned it and he inspected the flue he took some screws and screwed it down. He can not leave it like this that's what he mentioned. I believe he has noted it on his laptop.
What would you guys tell him this evening? The engineer of he asks for review etc
Tell him Worcester fixed the pump but 'at risked' the boiler due to the poorly fitted flue. You had to pay someone else to sort out the flue.
Thanks Scott,
I get your point but he will ask me now in 10 min he had to come anyway to commission the boiler. Why would I take someone else to make good? The boiler couldn't be left running as I said to him it isn't comssioned yet and therefore please isolate the gas and electrics. That's what worcest r did. Now I am on my way to him to let it sign off and benchmark fill per out.
Ronny the guy screwed you over problem is you need him to register it and complete the benchmark so probably going put up with it , i would not let him do anything else for you but your choice. Kop
That's the only hong they have filled out now ... I'm still here and I'll make ute I won't use this guy again.
How are they different hole is a hole,
me personally I would ar it
How are they different?
One is manufactured that way and tested with a TB stating its ok.
The other is an incorrectly fitted seal on the appliance with no such TB covering such a bodge job.
Surely this is just a simple case of being able to interpret the regulations. You are a clever guy, you know your are wrong , you just probably don't want to admit it.
Those figures on the benchmark are made up. 29ppm and 9.3% don't give a 0.0008 ratio.
What can I do ? They want to leave the casing off because they need to take the kitchen cupboard off and it's late they leave the boiler on with full electricity they said it's fine
What do you guys make of the benchmark ? filled in sitting in the van i bet ,You have named and shamed him now Ronny i would edit that bud while you can its a tricky situation you have got yourself in tread carefully mate its not registered until he does it with gas safe . Kop
The installer Shaun have a look at the benchmark those figures are not right and there things missing wheres the print offs of flue gas analysis i staple them to the benchmark .
It is already registered as he had to call them last week and they have asked about the address and what boiler it etc,.. I will call them tomorrow and will ask if the boiler has been registered. I will hunt it down trust me there.
cant be as ron said the boiler wouldnt fire and by the looks of it its fired
Reply to the thread, titled "What a nightmare in my eyes..." which is posted in UK Plumbers Forums on Plumbers Forums.
Old Account,
Last Plumber,
