K
Kmort78
Hello people this is my first post.Have been asked to help a customer with a ideal isar he 24 , I am a GSR engineer but have on the main only worked on install,so am a bit green on fault finding!!Before christmas the boiler had a pcb,new gas valve,condense trap clean,and spark electrode fitted by another engineer who can not be contacted!!! When i arrived the boiler would not run,I cleaned the syphon and heat exchanger which was blocked.Now the boiler will run on hign demand ,dhw on full as with ch, as soon as the dhw is turned off or reduced,and the fan speed slows.The boiler starts to vibrate and you get the whoop fog horn noise as if there is to much air to gas ratio?? but only happens on low demand,can the gas valve be ajusted,anyone know what is the cause..
