Apr 3, 2019
51
25
18
DIY or Homeowner
Hi..
We have applied for and are having a 'free replacement' boiler under the government scheme.
They will fit a Potterton Baxi replacement (tank fed) and Plume kit? boiler exhaust outlet is close to a kitchen window apparently
I'm just wondering what to expect apart from draining the system and hooking up the new boiler.. My old boiler is an Ideal Classic LXFF & FF Fanned Flue Gas Boiler
appreciate your comments
To be honest, what do you want for nowt?
Depends who the company you've signed with have subbed it out to.
And do bare in mind that whoever arrives to fit it was the cheapest they could find 👍
Maybe update with some photos of before and after once done.
Well it may sound like a complaint but it was purely to know what to expect..
Needing to clear rooms for him to access radiators etc
And no it isn't totally free to us either.
But thanks for your reply
Trying a bit of levity with the opening, Yorkshireman here.
How much you having to put to it and why if you don't mind me asking?
I apologise..
The surveyor has a scale of approval.. He worked out out to £460 contribution.. I don't know the true cost of ' just a boiler' but I know we're getting more than we paying. I don't know what access he needs in various places.. Want to help where I can..I used to be self employed and know the difference between a pleasant customer from and an awkward one
Make sure they flush all the radiators and pipework... especially when they tick the box in the benchmark to say they have 😁
£460 looks like you’re paying the labour cost
I apologise..
No need to apologise. Probably didn't come across as I intended.
As for access pretty much same as above. Radiators, boiler and loft for tanks.
And don't sign anything to say you're happy with the installation unless you really are.
You'll struggle to get anyone back to finish off anything they've missed.
The Energy Suppliers pay for most of the costs, if not all.
I suspect the installers are either on a fixed price per unit and win some loose some or are on very tightly controlled costs so can't afford to make return visits (or risk loosing money).
And it's probably too late to query it but check the length of warranty, I was looking the other day and saw an advert from an approved Eco installer stating 2 year warranty on a Worcester boiler, it's normally 5 or 10 years.
I assume the Energy suppliers are buying direct and getting a lower price with less manufacturers warranty.
Thanks Stu-B Is flushing, when 'just' fitting a boiler, classed as a standard thing or up to the fitter's discretion? Would that mean taking the radiators off or hooking up a filter system (which I have seen mentioned here and seen on YouTube... some large magnetic device?)
I don't want to make waves if it is optional.. I don't like confrontation at the best of times... LOL
I don't like flying blind.. if you know what I mean..
Flushing the whole system is usually a requirement of boiler manufacturers warranty.
From Pottertons T&C for Warranty claims,,
11.Boilers which have not been:
Installed and set up strictly in line with the installation instructions supplied with them
(including the requirement to clean the system and add corrosion inhibitor in line with BS7593:1992); or maintained strictly in line with the maintenance instructions supplied with them; or where parts other than Baxi Genuine Parts have been used in any service or repair; or where the Benchmark checklist has not been properly completed
This is really useful to know.. I suspect any boiler supplier would require this. You wouldn't change a car engine and put the previous engine's used oil in it?.. apart from the YUK!
When a replacement boiler is installed manufacturers require the system to be flushed to honor the warranty and hopefully prevent premature problems caused by dirty systems. It doesn't matter whether its a gas boiler, or oil boiler etc the system should be flushed. Depending on the original install and the state of existing system a flush could be a few hours, or it could take a couple days if larger than usual or incredibly fouled.
This is great information!
I suppose it's up to the installer, how he does this job..
Grateful..
Reactions: SJB060685
It’s a fat cat industry these days and right at the bottom of the pile is the boiler fitter, who is doing most of the work and getting paid the least. The firm who dishes out the work will be squeezing as much as they can from the fitter, I heard on the grapevine that these guys were getting half a days money per fit, so massive corners needed to be cut by them to in order to earn a decent living, first thing to go was flushing, second thing commissioning because let’s face it, if you’ve commissioned one then they’re all the same..... ish 😉
It’s a fat cat industry these days and right at the bottom of the pile is the boiler fitter, who is doing most of the work and getting paid the least. The firm who dishes out the work will be squeezing as much as they can from the fitter, I heard on the grapevine that these guys were getting half a days money per fit, so massive corners needed to be cut by them to in order to earn a decent living, first thing to go was flushing, second thing commissioning because let’s face it, if you’ve commissioned one then they’re all the same... ish 😉
will just leave this here
It's a joke isn't it. Last time I was renewing my gas there was a guy on there doing this type of work. He was doing combi conversions in a day with him and an apprentice, full TRVs. I dread to think what the work was like, i've seen other work done where we've lost out and it's usually dreadful.
What the above doesn't say is the Candidates must also be conversant with Covid safe working and implement it, which of course will add time to the jobs. Unless that advert was pre Covid.
As this work is ultimately being paid for by the big Energy Companies I wouldn't be surprised if they are going to be using auditors spot check.
The last thing they want is bad publicity around Covid.
Local Covid lockdowns are likely to affect whether a job can be done or not.
I'm worried now.. not sure what I'll be getting.
Everything crossed
Everything crossed
You won’t be getting any warranty that’s for sure
It’s a joke, I bumped into an old pal in the merchants he was picking up his boiler to do on a scheme, said they never flush or never get to full temp to measure flow/return temps, he said the inhibitor went in then followed by about a quarter of a bottle of cleaner just in case the water was sampled for a warranty fix.
yep no benchmarks/ valid results half of them arnt even registered
tec tite push fit on most pipe work
Wondering if I am courting trouble and should cancel..
What you think guys
aslong as you keep the points in this thread in your head then you should be fine
make sure they test the boiler with equipment probe should go in the flue they should do a range / gas rating and a gas tightness test and a flush at the minimum
well Collin came.. and soon started draining the system.... by 10:00 am the company asked for payment.. Collin wasn't pleased. I just said he hadn't finished yet.
I flushed it out with cleaner and then put inhibitor in about 6 months ago... I glanced over to see what colour the water was coming out and pleased to see it clear....
He started at 9:00 am and finished at about 4:30 pm. getting air out of the system was a pain.. boiler shutting down till the air got shifted. He was ultra considerate and gave us some tips on a few operational things...
I thought he worked hard and cleanly... I bunged him £40..
Any pictures of the final result? Did he check with a flue gas analyser? Did he fill out all relevant paperwork?
Sounds like a good sort and good of you to appreciate his hard work, if he bothered to give you some instruction he probably filled out the Benchmark. Check if he has.
sorry for the late reply.. I took a few photos
He spent a long time filling out the paperwork with his measurements... I wouldn't know what they mean. From taking so much trouble with the install I guess he did that properly too.
The Condenser outlet piping took some time but it was a neat enough job 🙂
Reactions: Pickwickpick
Update.. we were advised that an electrician would come back and check the wiring.. The gas fitter gave the impression that he would just fix his temporary mains cable into place..
Oh my god! We had a full test of the consumer unit, earth leakage, bonding, the whole house.. The works.. And he said it was an easy job.
Can't say I'm anything but impressed with the whole thing.
Dread to think what 2 -3 hours of an electrical engineers time is worth.. Or the actual job e did.
Hi..
I remember seeing 'scheme' work put in 15 years ago, (Isar - icos) to me they looked like good installs. I suspect every job will be checked after so the engineer will have to do what's required.
  • Love
Reactions: chucka
