C
clio182
only hot water never cold?!
^^ tried the above hasnt made any difference but i am a bit wiser!!!
i turn the tap on and get a pretty good flow, as the hot water starts to flow through the pipe the flow gets better (with out touching the tap or turning it any more)- say after 15-20 seconds - then the water is starting to get hot! then clunk clunk clunk and the flow is at required temp?! do you think its the tap????? thank all 🙂 only a couple of clunks but i would like to get rid of them!!
This is likely due to the temperature of the pipes led bulbs this is often the case with copper pipes.
Reply to the thread, titled "what caues hot water to gurggle in pipes" which is posted in Bathroom Advice on Plumbers Forums.
