Dec 1, 2018
103
14
18
DIY or Homeowner
So, first plumbing job in years, bought solder, flux and MAP gas as shown.
15mm copper pipe, shined up, fluxed, absolute failure!
I'm a sparks by trade and solder a lot but not with a flame.
Am I right to assume map is far to hot for an amateur to work with, I cooked the pipe!
Advice where I'm going wrong please, I cant afford a plumber!
Cheers.
Paul.
[automerge]1587827746[/automerge]
Cheers.
Paul.
As a follow up, these bits are for a shower mixer, can I use JG speedfit for the link to the shower head with the supplied compression fitting or must I use a plastic fitting?
Plenty of flux on it and make sure its 100% clean. Plenty of practice as well. 👍👍
I'm gonna get plenty of practice, five bed new build, done 150sq m underfloor heating downstairs now starting on the showers!
[automerge]1587844473[/automerge]
Are you cleaning both the fitting and the tube as for flux just a light coat all the way round the tube is more than enough
Yep, shining them up but maybe I need to shine the pipe more outside the fitting.
I'll get there with help!
It could be you have the flame too small now and all the flux is burning off before your adding the solder try turning the heat up a smidge maybe 1/3 of a turn on the valve
also Your using leaded solder switch to unleaded as you can’t use lead on water pipes these days
I will try that tomorrow.
Cheers.
Luggsey dont use plastic to connect the shower up remember once its covered over your screwed if it leaks and looking at that first attempt your 50 50 at best bud sorry to p_ss on your parade but i wouldnt want ya to have failures down the line 😂. Its really not that difficult to do in copper just add a few more noggings where you can screw a few brackets to, do the bracketing first clip ya copper pipes in they are easily removed for measuring a kick or set i have added a few pictures below of ones i have done how not to do aswell soldering is something that comes with practice and you really dont need loads of flux or heat clean the pipe with a cleaning pad if using brand new fitting theres no need to clean inside them , the flux only goes on the pipe a light smear is all thats needed and twist the fitting on to the pipe as you push it on swipe away the excess flux with a cloth apply a gentle heat and dab the solder on the joint when its hot enough you will see the solder run and be sucked into the joint (capillary action) always wipe the joint to clean off any runs and work tidy let it cool naturally then shine up with the cleaning pad.
[automerge]1587891583[/automerge]
Plenty of tips and how to do it on you tube bud
Cheers, I can take criticism ok, that's what I need to help me improve things.
I spent the last half hour before dark bending up a bit of copper to go direct to the shower head without joins so that's the way I will do the rest of the showers.
I have three more showers to do so lots to learn!
I have plumbed a house in plastic before and found it a stress free experience, i know most plumbers frown on plastic, preferring copper, each to their own ability I suppose.
Paul.
  • Love
Reactions: king of pipes
We will help you out where we can mate but please change those tap connectors they are compression fittings on the shower valve and Just need a short section of copper a nut and olive tiny smear of paste assemble and tighten you can then adapt to plastic with the appropriate fitting . Regards kop
I had a rethink and used copper, looks better to me!
  • Friendly
Reactions: Mrb
Always a pain to fit isolation valves and access them but its a water regulation and must be done, in a new build I like to manifold everything that way every water outlet can have its own isolation valve and fewer fittings. Kop
Will the isolation valves be accessible when you put up the plaster board?
I was going to fit the plastic framed access panel to do that, trying to work it where I know furniture will be.
Kop if I used a manifold I thought it would leave many cold legs and I have set up a comfort pump so couldn't do it that way?
Why ? It's no different all your pipework will have water in , I think you mean dead legs bud ? not really a issue in a medium size house, a secondary pump can be fitted if you want this circulates hot water to the points of use in your home usually Via a timed pump but obviously it involves extra pipework. Regards kop
  • Agree
Reactions: Jim Goodenough
No plastic on a secondary return.
That's a good point Simon 👍 there are ways of doing it but I am not going to complicate the post, as a medium sized family home with say 2 bathrooms , cloakroom , kitchen and utility room there's no need other than to avoid drawing amount of cold water to the point of use even this can be minimised with careful planning . All the best kop
Reactions: SimonG
Why would you bother running from the breach to the shower head in copper when the rest of the system is in plastic?
It would be the only part of a plumbing system that is never under any real pressure.
Simon please explain this to me, I'm a sparky!
The house is big, five bed, 150m2 ground floor, I obtained a bronze impeller pump to work off sensors in bathroom and en suites.
I don't know this reg about plastic on returns, can you please expand on that for me?
Thanks.
Paul.
12K
